Thread: 3.0 cdti K & N Filter change
    Regular Member M&S's Avatar
    Wirral
    Default 3.0 cdti K & N Filter change
    Well been on here a week now and I'm at it already
    New K & N filter arriving tomorrow and going to fit it. Anyone else done one on a 3.0? Any quirks to watch out for? I have had a good look around and it seems pretty straight forward if you have Torx bits.
    Anyone noticed a difference in performance and economy?
    Cheers!!!!!!!!!!!!!!
    Norfolk 'n Good Drives : Signum 3.0 CDTi BHP : 229.8 Torque 344.9lb
    Just take your time moving the ECU over as you lift it out. Its worth doing the air box derestriction whilst there too. Car runs smoother with less hesitation at low down pull away.
    Regular Member Harry's Avatar
    Uxbridge, London
    As above, don't rush.
    there are a few screws that you need to get to underneath the ecu in order to lift out the airbox cover
    Regular Member ALD's Avatar
    South Lanarkshire
    take you time, I dropped a torx screw and never seen it again
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    Quote Originally Posted by ALD
    me too! but i found it in the engine tray!
    Wirral
    Cheers gang . I'll keep track of the fixings then!
    The airbox mod? Is that removing the plastic piece off the base of the box?
    Has anyone tried cutting the output tube back as well?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    What does the airbox mod actually do as far as driving the car goes?.
    I know it allows a better flow of air, but I've read in some posts here that it makes a wee difference to low down power in some folks opinions.
    Is that indeed the case?.
  1. oil and filter change cdti 150
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2012, 11:22
  2. Oil filter change 1.9 cdti 150
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 09:39
  3. 3.0 V6 Cdti oil filter change
    By themarbleman in forum Engine & Drivetrain
    Last Post: 26th March 2011, 16:14
  4. Oil filter change on a 3.0 cdti
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 18:40
  5. oil& filter change 1.9 cdti (120) vectra est '05
    By bigsteve in forum Engine & Drivetrain
    Last Post: 8th October 2009, 05:36
