Thread: Dial changing/ complete cluster change
    Apr 2011
    Berkshire
    Default Dial changing/ complete cluster change
    Is it right that if you change clusters on the vectra c this should be re calibrated or it can potentially go into limp mode?
    Apr 2011
    Berkshire
    anyone have any idea?
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    its quite possible as everything runs through some kind of computer on these damn things
    al.
    Admin plasma's Avatar
    On the Forum
    247 Post(s)
    Engine : 150
    Mileage : 74000
    It will go straight in without reprogramming but will display the wrong mileage, also you need to stick to the same fuel source as well, ie if you have a petrol then get a set from a petrol car as the tacho/speedo will be out otherwise.
    Only drawback is it will log a code on the cars ECU about the wrong security code, but if you get that with the clocks then that can be reprogrammed at a later date.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    once you remove the clocks, you can take them apart and remove the pointers and then youl find that the front "peels" off quite easily and could probably be replaced with the sri type.
    al.
  1. diy clutch change complete
    By tugger434 in forum Engine & Drivetrain
    Last Post: 3rd September 2012, 18:55
  2. Tools for rear light cluster change?
    By Rockbird in forum Bodywork & Interior
    Last Post: 10th June 2012, 18:30
  3. dial change!
    By vec-cal in forum Styling
    Last Post: 8th May 2010, 23:14
  4. Changing springs do i need to change anything else?
    By aerodynamic18 in forum Suspension, Wheels & Brakes
    Last Post: 10th February 2010, 22:34
  5. BIG Thanks to Soulman - Springs and front disc change complete
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2010, 23:29
