Results 1 to 10 of 16
Thread: Can you diagnose this brake problem?
    Ripon, North Yorkshire
    Default Can you diagnose this brake problem?
    Vectra 2004 v6 Diesel estate.
    It failed the MOT on a rear o/s brake leaking.
    Brake was replaced. Picked car up and I notice the brake peddle with engine running has more travel than it did.
    Not bled properly I thought.
    Turned the engine off. then the brake peddle goes hard when pushed as expected as no servo action.
    Start the engine again and the brake peddle slowly sinks to the floor (almost). Is this leaking master cylinder seals, assuming there are no other leaks of course? Just air, as the servo will be adding a considerable compression?
    Nottinghamshire
    Quote Originally Posted by NPS View Post
    I noticed this on my DTi when I first got it (my first diesel car) and was assured that this is normal for diesels. It's due to the difference in the vacuum system compared to petrol engines, I believe. The pedal should go hard when the engine is off (like a petrol) but will slowly sink to the floor under continuous pressure when the engine is running (unlike a petrol).
    I'm not saying you don't have a brake problem but what the brake pedal is doing is probably normal. Can you remember what it did before you had this problem? It sounds like it may need more bleeding and/or brake fluid top-up though if the pedal moves further that it did previously before the brakes start to work.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Sounds like diesel creep and its perfectly normal, as long as it firms up with the engine off.
    The fact that it feel softer than before then is probably due to air in the system. The pedal creep is normal. Thanks
    Nottinghamshire
    It even has a name
    Perhaps back to the garage for a re-bleed and brake fluid top-up?
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by James24 View Post
    Not just diesels. Pedal will gradually creep on petrol cars when engine is on.
    No harm. Simply say to them that the brakes feel softer since they worked on them and can they check/rebleed them.
    Should I expect to pay for the extra work?
    Admin plasma's Avatar
    On the Forum
    272 Post(s)
    Engine : 150
    Mileage : 74000
    Not if you say the pedal feels softer, I'd except them to rebleed it again
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Nottinghamshire
    Thinking about it, isn't this what is know as a 'progressive brake pedal'? I think I remember that being the term used when I queried mine, but that was a long time ago. I didn't know it was the same now on petrols as on diesels.
    As above, the re-bleed and top-up should be free.
  2. Diagnose 1.9 Cdti 8v problem
    By smiley-sri in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:58
  3. PLEASE help diagnose
    By alijlacy in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2010, 19:48
  4. Let's see if you can diagnose this - Judder V6CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 21st May 2010, 13:28
  5. £50+ at Leeds Dealers to Diagnose my Fault??!!
    By H3MSY in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2006, 09:25
