Thread: EGR.. Valve.. Just quickie..
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default EGR.. Valve.. Just quickie..
    Hi Peeps
    Had an engine management light come, after a few days, took it too my local garage, he plugged in the reader and advised the EGR was at fault (he did say what the code, there were two, but I have forgot, sorry). Anyway he advised just to clear the code, if it comes back then it will need replacing.
    Since he has reset the alarm, have not noticed any change in performance during or since and doesnt appear to have chnaged the way the car drives..confused..
    It came on after the wife got stuck on the motorway on a hot day, stop/starting for an hour or two.
    So could it have just got stuck? and cleared?
    should I just replace it, or wait untill it re-appears?
    cheers for any experience... advise!
    DV
    Regular Member Innes's Avatar
    Plymouth
    it might be getting stuck because its gunked up.
    It'll be worth taking it off and give it a clean with carb cleaner. You'll need to get the new gaskets when you do this. HOW2 HERE for removal.
    Also clean the Boost Sensor whilst your in cleaning mode! HOW2 HERE.
    If it happens again afterwards then you may need a new EGR.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Thanks INNES..
    Z19DTH
    Engine EGR gasket 71751468
    EGR entrance gasket 55191883
    Asr these the 2 gaskets I need..?? anyone?
    West
    deffo worth a clean up first
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Also its only done 26K.... should it play up with so few miles on?
    appreciate a reply on the gaskets... cheers guys
    Plymouth
    Not sure about the gaskets. Perhaps call your local dealer to confirm.
    As for the EGR it depends how gunked up it gets by the maner in which its driven. If its alot of town driving at low-revs then it can get gunked pretty quickly.
    I've noticed that the 1.9 EGR's tend to fail quicker than the DTi's. Not sure why this is.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The egr gaskets (both) can be reused no probs!, be carefull removing them as i have done many times with 'no' leaks or problems.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    EGR problems in my oopinion for what it's worth and in spite of the potential risks - Blank it off.
    For what gaskets cost I would just buy new, but that's moi!!
    Gazza4
  1. another quickie mod to the B
    By Vaux-Man-G in forum Non Vectra C/Signum Album
    Last Post: 17th May 2010, 10:37
  2. A Quickie!
    By Matty777 in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2010, 01:24
  3. Just a quickie..........
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2009, 13:09
  4. Just a Quickie!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2007, 19:18
  5. just a quickie....
    By thegoldenbullet in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2007, 23:14
