Thread: Facelift Foglight Bulb change
    Liverpool
    Default Facelift Foglight Bulb change
    Hi guys
    sorry if this has been asked a million times, I have tried searching but couldnt get a definitive answer
    basically i just want to change my foglight bulbs, I've bought some off ebay, and i just need to know the best way about doing it? can it be done without a jack and/or too much messing around?
    Easiest way? Take the bumper off mate. You only need to take out the screws on the front wheel arches, one under each front part of the bumper and the ones along the top. You can then drop it forward enough to get to the lights. There are 4 plastic rivets that attach it on to the undertray but they can stay on unless you want to remove it completely which you don't need to do...
    Sep 2010
    yeah,... Ithink bumper removal (just a few torq scews) bumper off in 5 mins.. then easy access to fogs - unless you fancy bending back the wheel arch linings?.. might prove fiddly.
    stupid stupid design really, god knows why they do this for simple basic maintenance, stripping bodyworks is unacceptable in my book. - Will be doing mine soon
    Liverpool
    cheers guys, will give it a go this weekend
    Sep 2010
    bumper removal really easy,.. surprised myself, and as penfold says,.. leave the underside screws and lugs in and the whole bumper assembly will lower to the floor with no problem giving you room to do the job
    Regular Member irmscher72's Avatar
    northants
    The way i do mine is put car half on a raised kerb so you can lay down underneath then just unscrew the plastic cap underneath the fogs and there you go 10 min job all in Mtec bulbs all the way hope this helps ;-))
    Sep 2010
    what plastic cap underneath the fogs?! Not on the facelift there ain't
    11 Post(s)
    Quote Originally Posted by chewy71 View Post
    There is on mine. Big round cover that you rotate slightly to unlock and then remove.
    Sep 2010
    Had a right good look under mine,.. full splash panel from bumper to wheelarch,... no caps at all. ... s'not fair!
  1. help...indicator bulb change on facelift vectra...
    By mark-sri in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2016, 16:10
  2. vxr foglight bulb type please
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2012, 22:57
  3. Replies: 3
    Last Post: 20th December 2009, 10:33
  4. Replacing foglight bulb
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2008, 13:21
  5. SRi Foglight bulb?
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 02:02
