Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Limp Mode at 50mph
    Apr 2011
    Berkshire
    Default Limp Mode at 50mph
    On the 2.2 dti vectra I have it is being really sluggish, and as soon as I hit 50mph it goes into limp mode, anyone got any ideas?
    I have looked over the boost pipes and can't see any splits
    Also as soon as you turn car off then back on it out of limp mode
    north east
    Does it only happen when the car is upto running temp ?
    Regular Member Innes's Avatar
    Plymouth
    Have you cleaned the Boost sensor and EGR?
    Apr 2011
    Berkshire
    Happens when cold, and at temp, have cleaned egr, going to try boost sensor
    West
    You need to get the dtc's (codes read) it could be a number of things ie. MAF, vac leak etc
    Apr 2011
    Berkshire
    We had it on code reader and nothing was coming up
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    when my turbo actuator failed on my ford galaxy it gave the same symptoms, basically it would go like stink then cut out, you would have to stop the car to reset itself then start again,
    i had to have a new turbo fitted as they said it wasnt a seperate repairable part
    West
    You will need to have it plugged when the mil is on, that way you should get the code... also the dti's are not readable with every code reader.
    Apr 2011
    Berkshire
    We did it with rac, though I'm going to get tech 2 on it this week
    Can anyone tell me it it should have boost pipe connected to this
    Nottinghamshire
    Quote Originally Posted by MattHD View Post
    Yes, that black plastic box is the vacuum reservoir. If you disconnect the pipe, you'll hear hissing until the unit has filled up with air.
    Some fault codes aren't stored when they disappear, so you won't be able to read such codes unless the fault is ongoing at the time that the fault code reader is connected. The 'boost pressure out of range' error caused by a dirty/broken manifold pressure sensor is - if I remember right - one of these.
    I had the same symptoms as you. I cleaned the manifold pressure sensor but it still happened - although less often - so I replaced the sensor and it's been fine since. This - and then the EGR valve - are probably your next steps if all of the air hoses and vacuum pipes are OK.
  1. car going into limp mode 1.9 150
    By bingo999 in forum Engine & Drivetrain
    Last Post: 4th October 2011, 19:30
  2. Limp mode
    By irmscher-brett in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2010, 15:12
  3. limp mode still
    By trickster75 in forum Engine & Drivetrain
    Last Post: 24th July 2010, 22:03
  4. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  5. Limp mode?!
    By JimNZ in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2009, 09:57
