Thread: spanner light on for about 2 miles
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default spanner light on for about 2 miles
    as above .......from cold the spanner light comes on 2 miles(about 5 mins) later it goes off, i turned it off and back on once home from work and no spanner when warm anyone any ideas???????
    i don't have a code reader, i think i may have to get one.
    dont know if it helps but i think tickovrer may be up a little (cdti150 06plate)it's around 800/900 rpm
    cheers in advance
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    One of your glow plugs is going faulty , What happens is the relay detects the voltage from the glow plugs and if one is a little slower than the others it brings up the alarm that you see. If you get the fault codes read you are looking for a p0380 code .
    Not a serious problem in itself as the car can still operate normally in fact mine was like that for over 2 1/2 years before a second G P went faulty and i replaced them
    Quote Originally Posted by mrk View Post
    Providing the engine doesn't go into safe mode, then just watch it
    Equally, if it only comes on occasionally there is no major concern, the fault can be left until next service
    However, if it stays on all the time and/or the engine goes into safe mode then the car needs attended to
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Quote Originally Posted by bobssignum View Post
    as above fella its your glow plugs
    Sep 2010
    west sussex
    as they said ..glow plugs..
    West
    The plugs are around £10 each simple enough to change on the 16v, do all 4 at the same time
    Regular Member robk6112's Avatar
    Halifax
    Mine does this too- New glow plugs then for me too
    Trim : improving
    Year : 06
    thanks and big sigh of releif..................
    Aug 2009
    herts
    more reassurance? Glow Plugs!
    Mine did this, now does not.
    Multimeter on ohms settings shows a good glow plug 0.06 or below in the car. Positive on top of glow plug, negative earthed to the engine body itself.
    A bad one shows a number in the thousands.
    Or..change all four, start again fresh!
    Aug 2009
    herts
    and careful, brittle, dont want one to break off in engine block. WD40 or penetrating oil
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. Spanner Light Comes on For 1.5 Miles
    By peakfreak in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2010, 23:40
spanner light comes on for 12 a mile then goes off
