Thread: Sump plug 2.2DTi
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    Default Sump plug 2.2DTi
    my sump plug is knackered and i now cant get it out, what is better of the two evils of buying a new sump pan or getting a garage to drill it out? or i could drop the sump pan myself and try drill it out my self
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Removing a sump full of oil sounds messy. Better take the car to a garage and let them sort it for you
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    cant you get a pair of mollies on it. i recently changed my oil. i had to warm the engine up before the plug came loose. i had to use a torx socket with a 3/8 drive ratchet with my jacking bar on the handle to give me more leveridge
    Jan 2010
    Liverpool
    Mole grips or a good chisel on the edge of the plug.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    get the small hand pump and take the oil out through the dipstick hole and let the plug stay in
    Or you could remove the oil temp sensor from the front face of the sump and get most of the oil out that way.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. One sump plug or two on a VVT.
    By disco dan in forum Engine & Drivetrain
    Last Post: 12th October 2011, 18:36
  3. sump plug on my 2.2 sxi
    By smilerwas in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2010, 22:53
  4. Sump Plug Nut
    By si_hoss in forum Engine & Drivetrain
    Last Post: 22nd February 2010, 18:32
  5. Sump Plug ?
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2008, 14:59
