Results 1 to 10 of 17
Thread: 150cdti EGR bypass.
    Jan 2010
    Perkinsville, County Durham
    Trim : Sri nav
    Engine : Z19dth
    Default 150cdti EGR bypass.
    Been thinking this over.
    I've currently got an intermittent fault that only seems to appear if the iat goes over 50'c. Although the EGR is deleted in the ecu, under certain conditions, it opens up, and as I've also got the EGR blanked off a fault is thrown up.
    So, instead of blanking the EGR valve, why not block the EGR pipe at the exhaust manifold, then using one of the steel blanking plates available off eBay, drill a hole in it and weld on a short pipe just big enough to slide into one of those small k+n breather filters.
    Any thoughts?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You could but I would just blank it off as what you are doing is virtually the same thing. In fact this will make the mpg slightly poor in theory as the engine would be trying to draw air in through a smaller apperture. Just mu opinion though.
    Gazza4
    Jun 2006
    St. Helens,Merseyside
    it would also have a very good chanceof setting fire to the tiny k+n breather filter
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Quote Originally Posted by Mike DTI View Post
    Why, when it's just drawing cool air through it?
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Quote Originally Posted by Gazza4 View Post
    It is blanked off at the minute, but a fault occasionally appears when iat goes above 50'c. Allowing the EGR to flow (unblanked) and introduce cooler air into the manifold on the rare occasion that it is needed.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mally View Post
    As I understand it's drawing air from the engine bay so it increases the risk of catching fire.
    Gazza4
    Jan 2010
    Trim : Sri nav
    Engine : Z19dth
    Surely the air around the engine will be cooler that the air coming from the exhaust through the original EGR pipe?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I think the question is what are you after, your car running the best it can, or not having a little light come on once in a while..?
    You could argue that the MAP has fully removed the EGR operation and its this that needs further work/investigation.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    But you will have a filter filled with rubbish from the engine bay alongside. personally iwouldn't do it but if as dan says it is to keep the little light happy I would just get it mapped off.
    Also the cold are from the engine won't offer the cooling effects of the Exhaust gases as the cold air will be rich in oxygen and won't serve to reduce the nox emissions.
    Gazza4
    West
    by the looks of the first post the egr is already mapped out, yet still getting the fault
  1. egr bypass thought
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2012, 12:17
  2. CanBus bypass
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 08:58
  3. Red SRI Farnham bypass
    By bigboynigs in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 22nd May 2010, 13:46
  4. bypass ABS sensors
    By IA76 in forum Suspension, Wheels & Brakes
    Last Post: 18th December 2009, 16:53
  5. which is faster top end,150cdti facelift or 150cdti pre facelift?
    By andy d in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2007, 00:43
