Results 1 to 10 of 25
Thread: How to make my 1.9CDTi Wastegate Chatter
    Apr 2011
    Bracknell
    Default How to make my 1.9CDTi Wastegate Chatter
    Could anyone tell me how you can make a diesel wastegate chatter? You know like a dump valve sounds but more of a fluttering noise!???? HELP Guys!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    You can't because it doesn't have one.
    Gazza4
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    all turbos have a wastegate, a wastegate and dump valve are very different, ive had mine chatter a couple of times lol, as for getting it to do it more im not sure there is a way but with a straight trough exhaust you hear it alot more and it sounds the nuts
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    My wastegate chatters after a good curry
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by vxpenfold View Post
    not if its a vgt turbo.
    Regular Member Jaspa's Avatar
    Nov 2010
    nottingham
    Trim : GSi
    Engine : Z32SE
    Year : 53
    Mileage : 57,000
    on petrols...u get wastegate chatter by blanking any means of pressured air release...so the pressurised air gets trapped between throttle and turbo outlet
    the air has nowhere to go so its more like a strangling....altho it sounds cool as hell.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by Jaspa View Post
    sounds good......but very very bad for the turbine bearings.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Al 22 dti View Post
    Which they are.
    Gazza4
    Nov 2010
    sittingbourne,kent
    Mileage : 166000
    well then how comes there is a wastegate and wastgate actuator?
    and 1.9's arnt vgt are they, i thought it was only the 2.2 that was a vgt?
  1. 1.9 CDTi wastegate chatter???? Induction kit....
    By Vectra Adz in forum Diesel Engine related
    Last Post: 7th July 2012, 12:27
  2. 2.0t sri hod do i get turbo chatter?
    By ChrisChristopher13 in forum Petrol Engine related
    Last Post: 8th April 2012, 20:06
  3. Engine chatter.....dreaded DMF and clutch issues
    By marky2027 in forum Engine & Drivetrain
    Last Post: 24th February 2012, 16:50
  4. 19.cdti chatter noise help anyone at all
    By 0114NIGEL0114 in forum Tuning
    Last Post: 25th August 2011, 10:15
  5. Fault code P0243 (1.9CDTI 150) Turbo wastegate...
    By danBoy in forum Engine & Drivetrain
    Last Post: 4th December 2010, 15:45
z19dth wastegate
astra 1.9 cdti turbo flutter
vauxhall mokka wastegate chatter
1.9 cdti no turbo flutter
how to get turbo flutter 1.9 cdti
wastegate chatter on a vauxhall mokka diesel
cone filter csti 150 chatter
1.9 cdti what makes turbo flutter
why doesnt my turbo make chatter noise astra cdti
1.9cdti louder chatter
Wast gate for vaxuhall vectra tdi 8v 05plate
1.9 cdti wastegate adjustments
astra mk5 cdti turbo chatter
make 1.9cdti choo
zafira turbo flutter
vectra 1.9 cdti sri wastegate
opel signum wastegate
z19dth flutter
vauxhall mokka 1.7 dti wastegate chatter
wastegate dismantling vectra C 1.9 cdti 150 sri
make astra h 1.9 turbo chatter
vauxhall signum diesel wastegate
aatra 1.9 vdti sticky wastrgate
how to get waste gate sound cdti
vectra diesel chatter
