Thread: gear stick loose
    exeter
    Default gear stick loose
    i just fited a new gear stick and cradle to my vectra c dti and i have got a lot of play when in gear . does anyone know how 2 tighten it up ?
    Full Member spennny's Avatar
    Blantyre
    Isnt there a cap on the end of the white stick, someone had that issues last week on here,
    I will try and search for you
    Found It: http://www.vectra-c.com/forum/showthread.php?t=134261
    Full Member
    South West
    I have been trying to find a solution to this problem as well. The cap which spenny discribes is firmly in place with mine, its the grey tube with white caps and springs which clamps between the cradle which is causing my gearstick to have a lot of play.
    Its more annoying that in need of a real fix. Other than buying a complete unit and hoping it will cure it, i cant work out any other way to fix the problem.
    If you do... please let me know!!
    Rgds
    Aidi
    exeter
    spenny that is for a cdti and mine is dti so the gear stick is different and aidi you told me last time the stick can just be change on mine and it cant . vaux and scrapyards have told me it a complete unit stick and cradle . so i have had to get another one from a yard. i just need to know how to take up the slack on it ?
    May 2011
    BEDFORD
    I have the same problem too, looking for a solution, do i replace the gear stick unit or the cables ???? Also hard to get in 2nd gear on mine !!!
  1. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  2. gear selector come loose
    By nelly452 in forum Engine & Drivetrain
    Last Post: 3rd October 2011, 21:55
  3. Gear Knob loose?
    By lencuff in forum Bodywork & Interior
    Last Post: 7th June 2011, 22:59
  4. loose gear knob
    By studmuffin in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2010, 21:42
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
vectra c dti play in gear stick
gear atick know loose vectra
vauxhall gear floppy
