Thread: No Power Steering-You wouldnt believe it..
    kilmarnock
    Default No Power Steering-You wouldnt believe it..
    Ive got a 2006 Vectra 1.8 vvti and ive been having bother with the power steering, It would stop working and go heavy, then if you switched the engine off and started it again then the steering would work again.
    Anyway today was different it stopped working altogether, checked fluid level and all plugs going into the pump all seemed ok, checked fuses again all ok, then i came across this (see pic) A nut missing, now ive had this car almost 3 years and this must of been missing all that time... Put a new nut on and power steering is working ok again...
    Ive put this thread on so if anybody else has steering problems then this is something to check.. This is located next to the battery...
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Is there a cable that goes to it M8 as mine has done it a couple of times but not thought anything of it normally in bad weather ie when it is cold.
    kilmarnock
    Quote Originally Posted by Marc Hutton View Post
    Its a fuse by the looks of it.. right next to the battery.
    Theirs is a thick and thinner wire comes from the pos (+) on the battery the thinner of the two wires goes to this...
    Edinburgh/Catterick
    Happy days will give mine a check.
    Mar 2007
    Sheffield
    Thank you so much for taking the time to post this.
    I have had this issue today and because of your post I was able to make a effective roadside repair/bodge. I think I owe u a beer!
    Aug 2011
    Bristol
    Great Post.
    Just found I left mine off and that's my steering back to normal
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
