Results 1 to 10 of 11
Thread: Injector tar,,,,,
    Regular Member collyb's Avatar
    Mar 2011
    ireland
    Default Injector tar,,,,,
    hey guys,,,my 3rd injector has a mountain of tar,or coal like build up around the base of it,,,,is this just a simple washer replacment,,,???? and how easy of a job is it,,,,,and another thing,,,would this cause an engine light to appear on dash
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Common fault the plug needs replaced with the updated blue ones. It hasn't caused you problems yet but will eventually start interfering with the injector signals - shutting the engine off or puting it into limp mode. Part is about £15 from the dealer and £60 for the dealer to do.
    Gazza4
    Mar 2011
    ireland
    is it the injector itself needs replacing or just the plug into it ???? and should all four be replaced,,,,??? i was under the impression that just replacing the copper crush washers that was under the injector would cure the problem ?????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No the injector is fine, its the plug that is bad.
    Gazza4
    Mar 2011
    ireland
    im fairly handy with the spanners gaz ....wud this be a diy type of job,,or is diagnostic equipment required ????
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by collyb View Post
    Soldering - there is a how2.
    On your other thread however I noticed you have mentioned that cylnder 3 is leaking compression - there is another fault there then.
    Gazza4
    Mar 2011
    ireland
    nice one gaz,,,,would i replace the copper washers aswell as the plug ??? sorry for all he questions mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Tbh m8 I ain't 100% but don't do any work with ignition on or engine running, the pressure of the rail (28,000psi) is enough to sever limbs.
    Gazza4
    Mar 2011
    ireland
    hahaha,,trust me mate,,,keys will b out and battery leads takn off,,,,i will tackle it this weekend i think,,,will pick up the blue plug from the dealer this eve,,thanks mate
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Personally I wouldn't mess with the fueling system, period. I would do have a go at other problems on the car but no anything there. I'm not too sure if the pressure is residual or not if the engine off - so I would make sure first anyway.
    Gazza4
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. My 3rd injector went
    By Kramel in forum Engine & Drivetrain
    Last Post: 20th August 2012, 06:55
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. Injector 3
    By fadge in forum Engine & Drivetrain
    Last Post: 19th January 2009, 20:47
