Results 1 to 10 of 13
Thread: vectra cdti 150 help!
    Mar 2011
    Stamford
    Default vectra cdti 150 help!
    ok so im driving home this morning doing about 85 and all of a sudden i start loosing power, im low on fuel screen says 20 miles left so i thought i had a fuel surge. i pulled off the motorway and there is this horrible knocking like a diesel knock and loss of power i got the car home and now it wont start. ive put more fuel in but no joy. ive been told its the egr valve but ive cleaned it and its free and yes i know they can cause it to not start but knock?????
    any ideas as the knocking is worrying me. cars done 90,000 has full service history and up untill now was running a treat all stock exept k and n filter and irmscher back box. oh also no lights came up on the dash??
    also if you try to start the engine with the egr removed loads of white smoke that stinks of bbq comes out of the metal pipe the egr connects to??
    need sorting asap as better half is pregnant and need it to get her to hospital etc as its our main car.
    Chris
    Aug 2010
    Stoke on Trent
    Loss of common rail pressure or blocked injectors can also cause diesels not to start and knock when they do... white smoke can also be an indication of blocked injector/s... This ties in somewhat with your low fuel... maybe you've sucked up some muck from the bottom of your tank and blocked the filter or injectors...
    Mar 2011
    Stamford
    Quote Originally Posted by jimbojetset View Post
    when you try to start it with the egr removed it poors out white smoke, will check the filter housing out now thanks for the heads up.
    oh there is hardly any pressure at the injectors when you undo the unions and crank the engine this ties in with what you say no?
    Thanks again
    chris
    Mar 2011
    Stamford
    Quote Originally Posted by DTORU View Post
    Thanks again
    chris
    Ok so changed the filter and primed it but still wont start there is fuel to the injectors but it just cranks but no start????
    please help??
    Chris
    Birmingham
    Have you checked the cambelt?
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is the EGR back on while your testing it now..?
    Mar 2011
    Stamford
    Yes the egr is back on. Had the fault codes checked the below came up:
    Generator control circuit
    Fuel pressure regulator
    Fuel temp
    Fuel dossing sv
    Intake flow swirl throttle
    Fuel pressure rail
    Any ideas??? ****ed ecu maybe?
    Chris
    Really need this sorting at like I say other half nearly ready to drop with our first child and main car.
    Thanks again for all the help your a great bunch
    Mar 2011
    Stamford
    Fuel temp
    Fuel dossing sv
    Fuel pressure rail
    Chris
    southampton
    Have you checked the swirl valve control bar is conected on the inlet, sounds similar to the problem i had.
    Mar 2011
    Stamford
    Ok so an update the garage have found a fault and are saying it's the inlet manifold that's wrong? Can this cause a diesel knock and not starting ? I know it causes lack of power but not sure about the knock it was just like an old mechanical diesel knock when fueling or timing is out. Timing on car was fine to. Egr is new to.
    Chris
  1. 1.9 Vectra CDTi 150 VS 2.0 CDTi 160 insignia Sri
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2011, 11:38
  2. Vectra 1.9 CDTI Sri Versus 3.0 CDTI V6 Sri
    By collateral in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 20:18
  3. FS - Vectra SRI CDTI 150
    By rscosworth in forum Cars for sale
    Last Post: 16th July 2006, 22:11
