Hi Guy's
Can someone tell me if i should have a light on the dash to tell me when the headlights are on as i do not have any light to say there on.
The car is a 2002 vec c ls thank's for your time. Paddy
Hi Guy's
The dash lights would light up when sidelides are on. If you put the main beam on then there should be a blue light to notify you of this. But no light as such for dip beam though.
In mine (06 Design, facelift) when the sidelights are on the dash illumination level changes to "night mode" i.e. dimmer normally (which seems to be possible to set independent using the level control.)When dipped beam is on the green lighting indicator comes on (full beam is the normal style blue indicator)
Hi
Thank's for the reply, the dash lights come on ok but no blue light to say main lights are on what do you think.
Are the main beam on when you put them on. Just thinking the fuse might have blown?.
the green sidelight telltale light is only on the facelift although the blue telltale for full beam should come on when you pull the indicator stalk backwards (towards you)
right just been out & had a look & no blue light but all lights are working ok.
