Results 1 to 2 of 2
Thread: Power Steering Problems
    Regular Member Brooky18's Avatar
    Aug 2009
    Catterick
    Default Power Steering Problems
    Hope that someone will be able to help with this, as it starting to do my head in a bit.
    My Power Steering failed about 3 weeks ago, and I got the steering wheel and exclamation mark warning light. I had a checked around and found nothing obvious, fluid level ok, battery ok, alternator ok, so took it to a mechanic who told me the pump had gone. Not a problem, I sourced a second hand pump with a lot less milage, which was duly fitted. Upon starting the car uo for the first time afterwards everything was fine, pump was working and the steering was back to normal. switched ignition off whilst refitted inner wing, however on restarting the steering was heavy again, but no warning light and pump not working. So I checked on the forum and looked at problems that others had had in the past. So I have recehcked the Battery, alternator, fuzeable link, rechecked cleaned all the connection, fluid level ok.
    I work away so the car was left for the week whilst away and on return I tried to take on the problem again. Once more on initial starting the steering was ok and I could hear the pump, however the steering quickly got heavy again. turned off car checked fluid level ok and battery everything fine, but I ran the car up or about 1/2 an hour just on the off chance that was the problem, recheked afterwards still still nothing, but still no warning light, I did the pedal test to get any fault codes but nothing came up. I dont want to admit defeat and visit a rip off vauxhall dealer which will cost a fortune, but its getting close to it, so if anybody could please shead some light on this problem it may well save my sanity
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Not sure??? but i think you may have to programme the new pump and all volitile memories, i know you have to on the face lifts Vec c,s....
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  4. power steering problems after car wash
    By robertgsi in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2011, 22:38
  5. Power steering problems !!
    By mark_647 in forum Engine & Drivetrain
    Last Post: 23rd May 2009, 19:10
