Thread: Problem with camber!!!
    glasgow
    Default Problem with camber!!!
    Does anybody know how to change the camber on a Vectra C? I fitted coilovers a couple of weeks ago and the camber is different on both the front wheels so really need to change it before I get uneven tyre wear! Has anybody else had this problem before? It only seems to be the offside front wheel that is the problem as all the other wheels are sitting towards the arch but this wheel is pointing away from the arch.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Aryt Mate...
    You Should Go Get 4 Wheel Alignment Done
    I Did Straight After I Got My Coil-Overs And New Toyos On
    West
    deffo go for the full geometry setting up, the view is the hunter system is about the best
    glasgow
    Is this a common fault when fitting coilovers? What is envolved in the full geometry setup?
  1. Rear camber problem
    By mohojo in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 21:11
  2. Camber? Camber Kits??
    By RyanNI in forum Handling & Braking
    Last Post: 13th December 2010, 11:11
  3. camber kit
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2009, 09:23
  4. camber
    By linley85 in forum Handling & Braking
    Last Post: 30th November 2008, 15:05
  5. Camber
    By Daywalker in forum Handling & Braking
    Last Post: 22nd June 2008, 10:46
