Results 1 to 10 of 15
Thread: Power steering, HELP!!!
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Exclamation Power steering, HELP!!!
    Hi guys, i have a problem with my car. It has been off the road due to one coilover failing and now when i go to start it, it wont turn over and gives me a picture of the steering wheel and and exclamation mark!
    Anybody know what this is or had any experience with this problem?
    Thanks in advance
    Glasgow
    It's got a flat battery, give it a jump start.
    north east
    check battery + alternator outputs.
    Chelmsford
    Any fault codes?
    If it won't turn over, I'd say it's much more likely to be a power issue than a steering one. The car should start even if the PAS isn't even plugged in...
    Do the lights dim when you try to start it?
    Jul 2006
    Northampton
    Trim : Sri
    Thanks for the response guys, i think ill put the battery on charge over night and check it in the morning
    milton keynes
    Thats saying there is an error , possibly related to the CIM , power steering or ABS. Get the codes read , that will tell you.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    Flat battery will give up all sorts of codes... So charge the battery clear the codes and off you go... Unless your alternator is knackered then hand in pocket time.
    Jul 2006
    Northampton
    Trim : Sri
    right, battery is charged and still the error! Going to get the codes read tomorrow but any ideas guys?
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    does the car now start?
    Jul 2006
    Northampton
    Trim : Sri
    nope still wont start, just clicks
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
