Results 1 to 10 of 11
Thread: 2.2 dti egr valve
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Default 2.2 dti egr valve
    so my egr valve is messed up and its throwing the spanner light on straight away, whats my options, buy a new one or a second hand one if i can find one, or is there anything else i can do blanking etc? or rip the insides out and leave it open all the time?
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Davey have you had the codes read to confirm its the EGR
    This is the best price i can find at the moment for a new one
    http://cgi.ebay.co.uk/Vauxhall-Front...item4aaa15663b
    and still loving it
    Mar 2011
    Donegal
    no bob i havent got anything to read the codes and money is serious tight, sapposed to be moving house in 2 weeks also. but me and the girlfriends father had taken of the egr to have a closer inspection and when we put it back on, i had a constant spanner light, it takes about 15seconds sometimes for it to light up, cant drive it on limp mode, also i took of the side of the plastic on the egr to see if it was moving while connected and it didnt. have gotten a few qoutes over here and its 235 sterling. ill have to save for it. so you cant blank it etc? or bridge connections or anything?
    Mar 2011
    Donegal
    also if i get the egr valve replaced will i have to clear any codes or will it know straight away?? help lol
    Mar 2011
    Donegal
    im going to try a dealers tomoorow and see if they can do the blanking, hope so prob wont pass nct then though, ill put something in with the diesel to lower emmissions.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    davey it may want cleaning,i clean mine on my 2.0 dti twice a year to avoid problems.is the wiring harness in good condition.
    Mar 2011
    Donegal
    did some serious cleaning to it man, but the car is down on power since my sister owned it, she had it for 2 years, and how it finally gave in is, we took it apart to see if any internal damage, but when the womans father put it back together he bent the 2 prongs downwords so it didnt connect and i had spanner light all the way home, then i decided to futher investigate and seen the prongs werent connected, so i reconnected and it still the same, i reckon its gotten some electrical damage and it isint turning anymore, this could finnaly put the car right. id say it had an intermidate problem before when my sister owned it.
    Jul 2009
    Engine : 20 Dti
    i didn't know ther was some mechanical damage to the valve,then you will have to replace the unit.
    Mar 2011
    Donegal
    Quote Originally Posted by jonnybravo View Post
    ill see if i can get it blanked first, hopefully be alot cheaper.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    even if its blanked, the ecu will still see it as faulty and throw a spanner
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Troubleshooting
    Last Post: 6th July 2007, 00:43
