Thread: CD30 Replacing CDR 2005
    Stoke on Trent
    Default CD30 Replacing CDR 2005
    Hi,
    My CDR 2005 in my vectra is furbarred!! Wont load CD's and sounds like its full of nails!
    Can't be bothered taking it out to fix it.
    My question is, will this CD30 fit my 2004 SRi V6 CDTi?
    Cheers folks
    http://cgi.ebay.co.uk/vauxhall-stere...item33669ec01e
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quick answer is no it would cost you more to do it than it would fixing or even replacing CDR2005
    Irmscher Insignia CDTI 130
    Stoke on Trent
    ah marvellous!
    are there any other vauxhall standard radios that will fit? other than the CDR2005?
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    CCR 2006 will fit
    Stoke on Trent
    excellent.... i shall go on the hunt...
    I have, however, come accross this http://cgi.ebay.co.uk/VECTRA-C-SIGNU...item19c307e594
    Will it fit?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes but you will still have to do a bit of rewiring.. (look in the how2 section) both Bigmac and me replaced our old radios with nagivation system like the one you are linking to.
    but that is just the screen, you will need the radio also.. and will cost you about 300-400£ before you are finished..
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    have a look on google as opinions on this vary so much alot saying if you get the radio,display and leads plus tech2 it can be done without to much expense others just say forget it seems most money would be spent having a tech 2 session
    Engine : 2.2 Direct
    That depends on what you want..
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As said, it depends upon what you want..
    It is possible to fit a CD30, CDC40 and even CD70 to a half-CAN vehicle..
    But you need to get an SOT 122S lead to do the wiring conversion for you
    (plus some wiring know how..)
    You will also need any necessary aerial plug adapters.
    (You must also ensure that you get such a set up from an Astra-H or Vectra-C / Signum only).. Corsa-C / D, Omega-B, Astra-G are all wired up differently in the display plug).
    For those who have joined the forum in the past 18 months...
    "I fitted a Vectra-C CD70 and GID to my Non-CAN 1994 Cavalier, using this exact method"
    If you fit any other standard Half-CAN radio, then this will be nearer to plug and play.
    If you fit any of the high-end Half CAN units, such as NCDR2011, NCDC2013, NCDC2015 then these are do-able, but require a lot more additional wiring.
    So there are your choices.
    Stoke on Trent
    Well this is very interesting... im fairly capeable when it comes to wiring...
    To be honest though... I think i'll be getting another standard radio :-)
  1. Replacing CD30 with Kenwood DPX503U
    By vega21 in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2009, 23:55
  2. Replacing cd30
    By jrh1 in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2009, 18:16
  3. Replacing CD30 with new standard kit
    By jboofy98 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2008, 19:30
  4. Replacing the CDR 2005
    By vectraturbo in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2007, 11:41
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
cd30 to cdr 2005 adapter
cd30 adapter corsa c 2004
fitting screen to cdr 2005 vectra
cd30 or cdr2005
will cd30 fit in vectra c
cd30 cdr2005 conversion
vectra c cdr 70
