Thread: Vectra overheating to 100
    Apr 2011
    London
    Default Vectra overheating to 100
    Hi, hope you can help me to fin the root cause of an issue that I'm having with my car... I have replaced the radiator due to leakege but it is still overheating. This issue started because of the leakage but know that I have fixed that issue, the overheating has not dissapeared...
    Thanks..
    Barrow In Furness, Cumbria
    Is the coolant level correct? Is it leaking coolant anywhere? Has it overheated badly? If so it could be headgasket, other possibilities are the thermostat or waterpump.
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Also are the fans working behind the radiator?
    Regular Member Zark's Avatar
    Herts
    ^^ all of those - or airlocks??
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    All of those yes, airlocks? I thought that the Veccy had a self bleed/venting system, no doubt I will be informed if I am incorrect.
    Full Member Big Sig's Avatar
    Does it go upto 100 and when the fans cut in drop back down? Is it only in traffic or when on the move?
    Herts
    Dunno to be honest.... must be 20 years since I had to drain and flush a cooling system! worth giving the pipes a good squeeze though, maybe?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Could be a dead waterpump, with the engine running and looking into the expansion coolant tank do you see water returning through the 2 smaller pipes?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. Vectra C Turbo overheating
    By SriTurbo1 in forum Vectra C / Signum Troubleshooting
    Last Post: 9th October 2012, 08:03
  2. Vectra 1.9CDTI Overheating
    By brad69bj in forum Engine & Drivetrain
    Last Post: 19th June 2012, 15:47
  3. Overheating or not ???
    By Grahamy in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 19:22
  4. Vectra losing power & overheating
    By sr310583 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd April 2010, 10:58
  5. overheating/no hot air!?
    By P-Mutton2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 21st November 2009, 11:54
