Results 1 to 10 of 11
Thread: bad oil leak after garage oil change
    Oct 2007
    lincolnshire
    Default bad oil leak after garage oil change
    as some of you may or may not know i have a kit car (mk indy) so any servicing on my daily driver (1.9cdti 150 vectra) i take it to a local garage.
    anyway i had the oil changed saturday, now today i went to the local shop in the vectra and noticed ALOT of oil on the road on the way back and quess where the trail lead me to, yes, my house.
    now thers alot of oil on the road and none on the dipstick, looking under the bonnet it looks as if all the oil has come from the bottom of the engine.
    so what do you think ? loose sump plug ?
    any damage ? no oil lights on on the drive home and no new noises.
    advice please
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by graememk View Post
    advice please
    Don't drive it any further until it's sorted!!
    You've been lucky if there's no damage.
    Check the sump plug and the oil filter. Can only be coming from one or the other, if you've only had an oil change.
    Or take a walk to the garage who done it ..... :
    Once sorted, fill it and let it idle on the drive and check for leaks before you drive it
    Oct 2007
    lincolnshire
    do you think i should be asking the garage for it in writing that they did XXX and didnt tighten XXX just incase i have a big engine failure.
    just spent the last 2 hours spreding sand on the local roads around the village.
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    advice please
    Maybe Even Lost The Plug Mate..
    Let Us Know
    Oct 2007
    lincolnshire
    car was collected by the garage this morning, apparently the oil filter housing is cracked...
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    But ....... was it cracked before it went into the garage and was it holding oil 100 % before the mechanics got their hands on it ?
    they are probably just going to claim wear and tear or blame you for driving over something .
    do you think it's something the garage has done ? hit it with a hammer maybe .
    Oct 2007
    lincolnshire
    i'm the 1st owner and its only done 24k from new.
    lets see what excuse they come up with......
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I reckon they've over tightened the filter when they changed it. The plastic housings don't need to be super tight just nipped up
    Oct 2007
    lincolnshire
    well I've got it back, going to take it to another garage and check its been done correctly and not bodged
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    you will be the luckiest man in lincolnshire if there is no long term damage,be sure to keep the invoice for the oil change,with date, ect.
    as JR2 says filter has been overtightened.
  1. How do you change leak off pipes and injector seals
    By m.c.jones in forum Vectra C / Signum Car Chat
    Last Post: 4th April 2013, 22:41
  2. My Car was in Garage for Timing Belt and Water Pump Change
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2013, 22:31
  3. Anyone know good garage for cambelt change
    By Al 150 cdti in forum South Wales (RO - Vacant)
    Last Post: 30th March 2011, 13:22
  4. leak off pipe change
    Last Post: 21st September 2010, 19:31
  5. Replies: 14
    Last Post: 10th October 2009, 10:10
