Results 1 to 10 of 17
Thread: headlamps
    Regular Member Paddy's Avatar
    Mar 2011
    South East
    Default headlamps
    Hi Guy's
    Can someone tell me if i should have a light on the dash to tell me when the headlights are on as i do not have any light to say there on.
    The car is a 2002 vec c ls thank's for your time. Paddy
    Mileage : 000
    The dash lights would light up when sidelides are on. If you put the main beam on then there should be a blue light to notify you of this. But no light as such for dip beam though.
    Apr 2009
    Derby
    In mine (06 Design, facelift) when the sidelights are on the dash illumination level changes to "night mode" i.e. dimmer normally (which seems to be possible to set independent using the level control.)When dipped beam is on the green lighting indicator comes on (full beam is the normal style blue indicator)
    Mar 2011
    South East
    Hi
    Thank's for the reply, the dash lights come on ok but no blue light to say main lights are on what do you think.
    Mar 2011
    South East
    Quote Originally Posted by jong View Post
    Hi thanks for the reply i have no blue or green light when headlamp's are on
    Mileage : 000
    Are the main beam on when you put them on. Just thinking the fuse might have blown?.
    Mar 2011
    South East
    Quote Originally Posted by ed taylor View Post
    Hi
    Yes all the light are working ok, as are all the fuses,
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    the green sidelight telltale light is only on the facelift although the blue telltale for full beam should come on when you pull the indicator stalk backwards (towards you)
    Mar 2011
    South East
    Quote Originally Posted by plasma View Post
    Hi
    Thanks for that i am just poping out side to have a look but don't think it comes on.
    Mar 2011
    South East
    right just been out & had a look & no blue light but all lights are working ok.
  1. Headlamps - which?
    By SpiD in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2012, 19:01
  2. LED headlamps??
    By Mattle40 in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 17:07
  3. Headlamps
    By waltz in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2008, 19:19
  4. SRI headlamps
    By dazza1964 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2007, 16:27
