Thread: Scatty auto box
    Apr 2011
    walsall
    Default Scatty auto box
    hi all this is my first post love the site
    got my vectra 2.2 dti friday but its got a few little problems.
    First is a steering wheel logo in the my dash warning display but there does not seam to be any problem with the steering so cant work that out think it may be low fluid but cant find a filler for it anyone help me here
    Second is the auto gearbox cant decide what gear to be in and after prelonged use yeterday it only let me have 5th gear even if i put it into semi auto i could not change gear at first it was just 2nd and 5th stopped the car started it again and all was fine for a while the it went again then it just left me with 5th and it keeps swaping between gears at low speed also very shap and snatchy at pull away and between gear changes has anyone else had simler problems all help would be really welcome
    also cant find the tranmission fluid filler
    thanks in advance Andy
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I WILL be low fluid. The power steering reservoir is behind the driver's side wheel arch liner. Once you've got that off, reach in to remove the cap. Then feed a pipe down from the top, and pour fluid down to fill it up. You'll also need to remove a little filter inthe neck of the reservoir first, then you can feel the level, as it is difficult to see
    I'm no good with auto boxes, but sure someone else will be..................
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Er 2 and 5 is safe mode in the auto it means there is a problem somewhere
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi Aquire
    you need to get fault codes read,if you have code P0700,P0715,P0720.either 1 or all it,s.probably a faulty input/output sensor caused by moisture getting inside the sensor ,if so the cure is a new sensor,VX advise greasing the sensor plug now to keep out moisture
    as for the steering as tony says.
  1. Auto Wipers and Auto Headlights
    By skip85 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2012, 01:12
  2. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  3. Auto wipers.. and auto dimming mirror ?
    Last Post: 28th January 2009, 01:24
  4. Auto Dimming Mirror/Auto Wipers
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2008, 21:42
  5. Vectra 1.9CDTI 150 Auto v 2.2Direct Auto
    By mattr in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:16
