Thread: beebs when turning ignition off
    Ripon, North Yorkshire
    Default beebs when turning ignition off
    My Vectra 2005 v6 diesel makes a number of beebs when the ignition is turned off. Has done so for the last three years. Just realised this may be to indicate there are fault codes recorded. Also if the indicator stalk is held up or pushed back(not sure which) it produces a series of beebs that sound like the same as the error codes shown on the dash flashing light when the pedals are held down.
    I havent recorded the beeb counts but from memory there was a two, severn then a further two numbers. Does anyone know about this and can help?
    11 Post(s)
    Quote Originally Posted by NPS View Post
    That's to notify you that you've switched on the parking lights.
    By moving the indicator stalk either left or right will put on the front and rear side light on either the left or right of the vehicle and also show the green indicator arrow in the speedo housing for approx 1 minute.
    If you have the headlights on, then switch the ignition off, the headlight warning comes on
    A continuous but slow, bleeep - bleeep - bleeep
    Solution is to open then close the drivers door, or to switch the lights off, then back on again
    Barrow In Furness, Cumbria
    Does it still beep when you remove the key from the ignition before opening the door?
  1. Turning Over
    By Diet1985 in forum Engine & Drivetrain
    Last Post: 21st August 2009, 22:49
  2. Fao beebs
    By bertbuckie1 in forum General Chat
    Last Post: 12th April 2009, 12:20
  3. Looks like i'm turning.
    By shan in forum The 'Off Topic' room
    Last Post: 3rd February 2009, 13:55
  4. Turning your Wii 3d
    By rosssri in forum Games Room
    Last Post: 12th January 2009, 18:41
  5. Clicking noise only when turning ignition
    By mbonnick in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2007, 07:10
