Results 1 to 2 of 2
Thread: vectra misfire
    Mar 2011
    Galmpton
    rolleyes vectra misfire
    Hi. Son,s car vectra B 1.6 16 valve 2001 has misfire at low revs and error code po353 shown. This says Ignition coil c primary/secondary circuit malfunction. Plugs were filthy and we have changed them. Code deleted but returns.
    Can anyone help.? Is it likely that a new coil pack would solve this problem. Son is skint so do not want to go to garage. I would welcome any useful ideas. Thanks, Ian.
    Mileage : 000
    Sounds like the coil pack. It happened to our "old" Vectra B. They use whar is called a wasted spark. What that means is they fire twice. Once to ignite the fuel then on the exhaust stroke they fire again to burn off any un burnt fuel. On ours two plugs lost their "spark". Was a bit of a pig to "limp" the car two miles home. New coil pack sorted it though.
  1. Vectra C 2.2 Misfire on Cylinder 3 + 4
    By m2yuout in forum Engine & Drivetrain
    Last Post: 12th February 2013, 13:14
  2. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  3. Vectra 2.2 Direct intermittent misfire?
    By simp_2.2sri in forum Engine & Drivetrain
    Last Post: 23rd April 2011, 05:59
  4. 2.0 turbo vectra low idle maybe misfire??????
    By vectra100turbo in forum Engine & Drivetrain
    Last Post: 1st February 2011, 17:36
  5. Vectra 1.9 CDTI SRI Nav Misfire??
    By Joe1 in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2008, 09:45
vectra misfire at low revs
vectra c misfire low revs
