Results 1 to 3 of 3
Thread: vectra c
    coventry
    Angry vectra c
    hi i have a 2.2 dti on a 53 plate it turns over but will not fire up,flattened battery trying,any body help, i think it my be glow plug, but how can i find where they are and how do i change them thanks
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Too warm now to be glow plugs. Might be a fuel problem. Have a look through the how to section for the guide on how to start a DTi with air in the fuel lines. Check the fuel filter too, mine was blocked and had stopped the car from starting.
    NW
    Quote Originally Posted by petrolheaddude View Post
    Check the butterfly valve in the throttle body is not stuck closed. Use your finger on the vacuum actuator to check for free movement. If its the same as the 2.0 dti the valve closes when you switch off the engine, then opens again after a few seconds. My wife's zafira was not opening again. just disassembled it this weekend and cleaned it out with carb cleaner.
    Had it in a garage the other day and they told us it needed a new diesel pump. It actually would not start for them and the idiots could still not find the fault.
    Steve
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
