my cars is 08 2008 reg covered 40k
started using ac with it getting warmer and seem not work
lights up when i press button and can feel increase in power from fan but doesnt get any colder
will it just be a re gas ?
Yep -
( unless the reason it needs a re-gas is a hole somewhere )
if your lucky yes, if not new condenser, dont think its the compressor as you say it's been running, quick fit offer a recharge and if it fails yor money back, can't loose.
Mine is the same been saying for the last 6 months I'll fix it still haven't just enjoying the breeze to be honest
mine been same (08 too) .. VX recommend a re-gas every year. Folk on here suggest it's used EVERY week,.. even winter, to keep the seals lubed
whats the price of re-gas if no leaks found anyone?
40-45 minimum.
"VX recommend a re-gas every year"
If you leave it on permanently that shouldn't be necessary. You can still heat the car in winter but with the added benefit that the air is dehumidified.
You don't have to wait until it gets warmer to use the AC. You're meant to regularly run it throughout the year to prevent seals from drying out and losing the refrigerant gas.
Yep, that's basically how climate control works. You can use bog standard AC as climate control by manually adjusting the heater knob. Makes for a great demister too.
