Results 1 to 10 of 11
Thread: Buying advice 08 sri 150 what should i look out for
    Regular Member duncmill's Avatar
    Apr 2009
    manchester
    Default Buying advice 08 sri 150 what should i look out for
    Going looking at a black 08 1.9cdti 150 sri 101,000miles tomorrow what questions should i ask common problems ect? Cheers.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Check swirl flap bar moves freely when engine revved (inlet manifold).
    Listen for rattle that disappears when pressing clutch (Dual mass flywheel).
    Poor performance under 2k revs (EGR valve).
    Make sure timing belt and water pump have been done within the last 40k miles.
    hth
    Regular Member cockney16v's Avatar
    stoke on trent
    The manifold was a revised part after 07 so I was told
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by cockney16v View Post
    Very true. Car could have been manufactured in early 2007, and remained in stock until 2008. Possible, but not likely.
    Regular Member gaz1965's Avatar
    Mar 2011
    Putney London
    Trim : SRI 150
    Engine : 1.9 CDTI
    Stupid question but where is the swirl valve?
    Chelmsford
    In addition, do the usual checks which apply to any Vec...
    Coil springs in one piece (front and back), no knocking/squelching over speedbumps (cheap easy fixes, but will be handy to know, especially if you're trying to knock a few quid off!)
    Also check for any sign of dampness in the boot (below the carpet), there are several ways water can leak in (poorly sealed aerial base, rivets in roof, bad window seal)
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    quite high on the miles for an 08 m8,i wouldnt get another high mileage
    i had 06 zaffy b 1.9cdti 150 and had 112000 on clock and i had to-
    replace gearbox
    flywheel n clutch
    turbo
    egr valve
    alternator
    never again i get high mileage but upto you m8
    West
    Quote Originally Posted by andy.l View Post
    replace gearbox
    flywheel n clutch
    turbo
    egr valve
    alternator
    swings & roundabouts matey... my high milers have been far better than the Zaffy i bought with 35k on it
    That's more your choice of a bad car than all high mile cars.
    replace gearbox
    flywheel n clutch
    turbo
    egr valve
    alternator
    Also Jay kay's car on here forsale would probably be a much better buy.
  1. Need advice on buying a GSi
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2011, 19:33
  2. buying advice
    By astra_baz in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 04:46
  3. Buying help and advice please...
    By dog in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 13:23
  4. Buying advice
    By biglee55 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2009, 13:23
  5. a bit of advice when buying a car
    By pogo in forum General Chat
    Last Post: 21st June 2007, 09:48
