Thread: Newbie & Keyfob plus
    Apr 2011
    Kent
    Default Newbie & Keyfob plus
    Hi All
    I have just purchased a 03 Vectra 3.2 Elite this week.
    I have replace the batt in one of the fobs, but cannot sync it. Shows immobilizer on dash.
    I have done a lot of searching but no on ever completes the post!
    1. Can "I" sync it or a main dealer?
    2. Will I need to purchase a new key?
    The car has not be serviced for just over a year but has only done 500 miles in that time. it has 66450 on the clock. Should I get a full service done or just an oil change.
    Mileage : 000
    I would think that if it shows immobilizer on dash? then it might need to be taken to a VX dealer.
    But try this first. In this case I don,t think it will work, but worth the try.
    Put key in ignition.
    Turn it on. ( dash lights on, but don,t start it though).
    Press either the open or close button on key fob.(buttons on top of dooor should "pop up and down"). If so you might be in luck.
    11 Post(s)
    The immobiliser doesn't rely on the battery in the fob. The battery is for the remote central locking only. You could remove the fob battery and the engine should still start as it uses a transponder chip inside the fob that communicates with the ignition barrel.
    Also, the resync procedure is only for the central locking.
    An immobiliser related fault will need something like Tech2 to diagnose and hopefully marry up the fob to the car again.
    Apr 2011
    Kent
    Thanks Guys. As soon as I put the key in to the on position the immobilizer lights up.
    The other key is fine.
    Mileage : 000
    Does sound like a trip to a VX dealer to get the offending key configured to your car again.
    Apr 2011
    Kent
    Quote Originally Posted by ed taylor View Post
    Thanks. Any idea how £££ I'm looking at?
  1. keyfob swap
    By DAVIDD88 in forum General Motoring Chat
    Last Post: 21st July 2012, 23:59
  2. Replacement Key/Keyfob
    By tol1013 in forum North East RO Vacant - ARO - Vacant
    Last Post: 23rd December 2011, 01:00
  3. Keyfob Mod
    By Aidi in forum Styling
    Last Post: 8th October 2010, 10:20
  4. keyfob / key
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 20th July 2010, 21:56
  5. HELP with keyfob!
    By byebyeitsagsi in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2009, 22:36
