Results 1 to 10 of 15
Thread: 2.0 dti fuel timing error code p0149
    Apr 2009
    manchester
    Default 2.0 dti fuel timing error code p0149
    Car has started to run rough on tickover,if i hold the accelerator on constant revs the engine surges.Also when driving ,the car will lose power then pick up with a puff of smoke from exhaust and eml light will come on for a few seconds.
    Code reader picks up code p0149 fuel timing error.
    Anyone had similar problems and found a solution,If it is the fuel injector pump i cant see it being worth doing.I rang vauxhall and they want £2000 for an exchange unit and it would then need programing.
    Apr 2009
    manchester
    bump and a bit of a worrying update,changed fuel filter and found tiny shiny metal bits in bottom is that a sign of the fuel injection pump self destructing.
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    sorry to say but little metal bits in filter is normally a sign of diesel pump on its way out.
    north east
    try holding the speed @ 80 mph once the engine is upto temp and ee if limp mode happens. metal sounds like uel pump but that could have been sat there for years if you don normal empty it and the fault could be the crank haft speed senor as this controls fuel timing
    Apr 2009
    manchester
    Car is now running too crap to drive any more,i have changed crank sensor and map sensor with no difference.
    I am trying to find a second hand fuel pump,I know this will require programing with tech 2 at the stealers but what info if any do they need from the donor car,need to get this sorted now and get rid.
    Gutted because i liked the car and its only done 70000 miles.
    Regular Member dervb's Avatar
    Jun 2007
    Thornton merseyside
    i am bit concerned how the metal fragments have got into the filter in the first place, as the pump is down stream of the filter housing.
    Apr 2009
    manchester
    Fuel return?
    Jun 2007
    Thornton merseyside
    got ye m8, fuel rtn to the tank , then sucked back through to the filter and so on...
    Jun 2007
    Thornton merseyside
    i was just thinking of the price for a pump o/haul, think its about £2-300 ?
    Jun 2007
    Thornton merseyside
    just found this website hope it helps.
    http://www.dieselpumprepairs.com/?gc...res/4533030669
  1. Error code reading and code readers
    By Ben50n in forum Engine & Drivetrain
    Last Post: 27th August 2012, 16:43
  2. error code
    By riauba in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 21:43
  3. Error Code
    By slipperysam1984 in forum Engine & Drivetrain
    Last Post: 7th July 2010, 17:52
  4. Error code help
    By Cat_J in forum Vectra C / Signum Troubleshooting
    Last Post: 18th January 2010, 17:48
p0149
p0149 opel
p0149 fuel timing error vectra c 2.0 dti
vauxhall vectra 2.0 dti p0149
error code P0149
https:www.vectra-c.comforumshowthread.php134805-2-0-dti-fuel-timing-error-code-p0149
p0149 opel zafira
Opel DTC P0149-5A
opel zafira 2.0 dti 2005 code p0149
Opel DTC P0149-3
p0149 fault code vauxhall
vauxhall p0149
p0149 code
p0149 opel 2.0 dti
http:www.vectra-c.comforumshowthread.php134805-2-0-dti-fuel-timing-error-code-p0149page2
p0149 vauxhall
po149 opel vectraopel vectra 2004 2l2 cod difo p0149OPEL P0149p0149 opel zafira dieselopel vectra c 2.2 dti P0149vectra c p0149 hibakódp0149 fault codeOpel DTC P0149-5Bfuel timing eeror vectra
