Thread: What Oil In The Vectra
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default What Oil In The Vectra
    Been Told By A Mechanic To Use
    5W/30 Fully Synthetic In My Vectra 2.2 Sri
    And To Clean It Out With
    Forte Top End Treatment or Slick 50
    This Will Get Rid Of My Mayo Problem
    What Oil Do You Other Guys Have In Your Car ??
    Is This Ok
    Full Member Big Sig's Avatar
    That's what it came with from the factory.
    Will it cure your Mayo problem? Depends, what's causing it? It may only remove it until the water builds up again.
    Mar 2011
    Northamptonshire
    well the guy who had it before me did not go very far in it .but a blast to skegness last week got rid of it from the oil filler cap.
    i am thinking the mayo is in the tappets ,as it sounded like a diesal this morning at start up for about 5 mins
    East Kilbride
    Engine : 3.2 v6
    Mileage : 110,000
    Do you have the elongated oil filler? It is a platic pipe about 4 inches long. If you do take it off and put the filler cap directly on to the rocker cover. I did that with mine and hey presto no more mayo in the top of the pipe or on the cap.
    The longer pipe is only for ease of filling, and acts as a cooler when fitted. This cools the oil vapours and causes it to emulsify thus giving you the mayo effect.
    There are a few posts about this from a few years back try a search for it.
    3.2 v6 Signum and loving it
    Mar 2011
    Northamptonshire
    no mine screws directly into the rocker cover
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    i'm using genuine vauxhall semi synth in mine, i used to use magnetec years ago but i personally beleive you can baby an engine too much,
    11 Post(s)
    Quote Originally Posted by viper8 View Post
    I do both short and occasional long distances. Regardless of the distances I do, my engine still suffers with mayo on the filler cap of my 2.2 Elite.
    Its a 'characteristic' of the engine in that the top end doesn't get hot enough to get rid of the water vapour in the oil.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
