Results 1 to 3 of 3
Thread: Fan Belt Tensioner
    Blackpool
    Default Fan Belt Tensioner
    Whats the best way to loosen it guys?
    ot should have a hex or square socket in it
    probably square
    fit a socket into the hole and turn it usually clockwise
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    I fitted a new belt on my 2.2DTI last week. To gain access I lifted the driver side with the Jack and put it on a axle stand. then removed the bottom plastic dirt gaurd 6 or so star screws. then I dropped the dirt gaurd from the wheel arch only one star screw. I think I had full lock on the steering to give more room before starting.
    To gain access from the top remove your air box.
    there is one star bolt holding it at the bottom and one in the middle but you will need the socket to fit, e14 and the next size up. I needed to grind two flats on the e14 socket with my bench grinder so I could get a spanner on to slacken it off. There is no room for a ratchet.
    To put it back on is the reverse. When putting the belt on you will need to put a spanner on the nut that is next main wheel on the tensioner and use it as a leaver to move the wheel to allow enough slack/room to get your belt on. I hope this helps?
  1. fan belt tensioner
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 15th December 2012, 11:50
  2. Aux Belt Tensioner
    By tatters40 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2012, 23:02
  3. v belt tensioner
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 00:10
  4. Aux belt tensioner
    By jamesr in forum Engine & Drivetrain
    Last Post: 15th December 2008, 20:56
  5. Aux belt tensioner on 3.2
    Last Post: 10th September 2008, 21:22
how to slacken belt tensioner z30dt
