Results 1 to 10 of 26
Thread: 120 or 150
    Regular Member tommythomson12's Avatar
    Mar 2011
    Rochdale - North-West
    Default 120 or 150
    What is the easyest ways to tell the difference between a 120 bhp vectra ctdi sri, and a 150 ctdi sri
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    2 ways usually...the cdti badge ...the T is red ...also the position on the oil filler cap on engine ..and also the v5 book (but this is not always correct lol)
    Mar 2011
    so on a 150 should the filler cap be on the right and a 120 on the left
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    You have to be careful there. A 120 and 150 16v both have the oil cap on the right hand side, but the 120 8v has the oil cap on the left hand side. If you are deciding on whether to buy a 120 or 150 16v and are going to modify it (performance wise), then buy a 120 16v version (which should cost less than an equivalent 150 16v), but as they are exactly the same engine, you can have it remapped to the same power as the 150 16v. Hope this helps.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by george1987 View Post
    spot on george m8.
    Gazza4
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    why not just look down at the manifold if you're not sure
    swirl valves on the manifold = 150ps. Or just test drive it - if it's slow, it'll be the 120hp. The 150hp should have fairly decent acceleration.
    a red "TI" plus the position of the filler cap should be enough to be 99% certain it's the 150ps.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Hideous View Post
    Won't work as some 120's were released as 16V, so the oil cap will be on the right and swirl flaps will still be present.
    Gazza4
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    i've never seen or driven a 16v 120ps, looked at loads.
    myth until there's some evidence.
    just drive 120ps and 150ps and see the difference for yourself.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I'll give you that - neither have I, BUT they are in some of the Astra 120's So I disagree there.
    Gazza4
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    so why is the 120 slow ???????????????
    Midlands Mod Shop - NFFC.
