Thread: z22se wont turn over HELP
    Apr 2011
    wales
    Unhappy z22se wont turn over HELP
    Hi there i have a 52 plate vectra c sxi
    the problem i have is it will not turn over on the key a relay just clicks by the glove box the battery is new so it cant be that if i cross the starter it will turn over fine i just have nothing on the key just a clicking relay i can read the ecu no faults found i am loosing the will to carry on lol can some one help please
    Regular Member benny's Avatar
    Feb 2006
    dudley
    is the starter relay ok in the uec ..?
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by mike060280 View Post
    If you use full stops, it'll help us work out what scenario you're describing, rather than having to guess whether it's the glovebox, relay or battery that is new.
    Apr 2011
    wales
    What one is the starter relay? Is it one of the yellow ones next to the battery.
    Apr 2011
    wales
    Found starter relay.
    Changed it with the relay from my other vectra, no joy. Dont know what else to do. Any help would be great thanks Mike
    Apr 2011
    wales
    I have power down to the starter 12v all the time on the red lead and 12v on the little lead when the key is turned to the start position but the stater does not turn ????. I can put a screwdriver accross the + on the starter motor to the little wire on the starter motor and it will turn over is this bypassing the soliniod and thats why its turning???
    Could it be the starter???.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    if you do above with ignition on will it start? yes that by passing the solenoid if it starts you need a new solenoid
  1. turn the key and nothing!!!!!- Wont start
    By Rupster_69 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2013, 13:13
  2. Vectra wont turn over
    By stevie b in forum Vectra C / Signum Troubleshooting
    Last Post: 14th November 2012, 20:57
  3. please help vectra 2.2 dti wont turn over
    By deano1 in forum Engine & Drivetrain
    Last Post: 20th May 2011, 21:37
  4. HELP!! car wont turn over!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 31st March 2011, 19:08
  5. Blowers wont turn off
    By KieronGSI in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2008, 08:21
opel vectra z22se reads key but cannot crank
