Results 1 to 10 of 17
Thread: Noisy Top End
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Noisy Top End
    my vectra seems to have a noisy top end rattle coming from the top cover .
    could it be the tappets ?
    had a problem recently with mayo on the oil filler cap and in a breather pipe .this is because the guy who had the car before me did not go very far in it ..
    cleaned these out .but could mayo be in the hydrolic tappets .or in the top of the cover ?
    is there something i can put into the oil to remove the mayo ?
    can anybody help me with this
    car is a vectra 2.2 sri direct
    29000 miles
    Mar 2011
    Northamptonshire
    Anybody Have any ideas
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Mayo in the oil used to be an indication of head gasket.... Dunno if that would cause a rattling noise though
    Mar 2011
    Northamptonshire
    would it be on the dipstick as you pull it out
    Aug 2010
    Leeds
    Get it hot and drain the oil and filter.
    Then take it for a good blast up the motorway take the revs high through the gears and any sludge in the hydraulic tappets should shift.
    The mayo is from local runs and the oil not getting hot & no need for engine flush.
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    maayo would be underneath the oil cap mate...you might get some on the dipstick too....also check the water reservoir too for oil mixing in the water...
    just helps to rule out these problems
    thanks,
    swansea
    Eek
    Quote Originally Posted by Bigtee View Post
    Are you sure
    Aug 2010
    Leeds
    Quote Originally Posted by jrh1 View Post
    Are you sure
    Yes why?
    The op is reffering to the hydraulic tappets so i asume he's had it checked, it could be worn cam gear etc.
    Mar 2011
    Northamptonshire
    Just started the car this morning to take the mrs to work .and it sounding like a diesel .rattling like mad .
    took about 5 mins of driving to go away ..
    Help
    Regular Member westonprawn's Avatar
    Jul 2009
    TELFORD
    Is the oil at the right level? Daft question but you never know
    Justin
  1. Noisy Fan!
    By suresh.chohan in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2011, 20:30
  2. Noisy Air con
    By chief29 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 19:19
  3. Noisy A/C
    By multi in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2008, 20:03
  4. noisy car
    By mac12 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 14:08
  5. noisy air con
    By John35 in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2007, 14:14
