Thread: Auto-Dim Rear View Mirror
    Aug 2010
    Stoke on Trent
    Default Auto-Dim Rear View Mirror
    Has anyone retro fitted an Auto-Dim Rear View Mirror ?
    I have a mirror and a cable on the way... is there anything else I need or anything I need to be aware of...?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Have a gander through these.... may help you:
    Post #4 of
    http://www.vectra-c.com/forum/showthread.php?t=81417
    and
    http://www.vectra-c.com/forum/showthread.php?t=44805
    All you need is mirror unit, harness (flat cable), a couple of torx drivers, and a bit of patience. Whole job took me about an hour.
    Aug 2010
    Stoke on Trent
    Thanks for the links... I've looked at both but neither mentions how to remove the standard mirror... or how to physically fit the new mirror... is this bit easy to do..?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    The standard mirror is held onto a dovetail mounting that is bonded to the screen.
    To remove the standard mirror it is pushed down, along the line of the glass, toward the base of the windscreen. If memory serves, mine needed a bit of a tap to get it moving.... just avoid using too much hand or mallet impact if the screen is very cold.... cracks are expensive.
    The new mirror conversely slides up the empty mounting until it clips into place.
    Aug 2010
    Stoke on Trent
    Coolio.... cheers
  1. Auto dim rear view mirror
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 19th August 2012, 09:56
  2. auto dim rear view mirror
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2011, 23:07
  3. Auto dip rear view mirror
    By masonic in forum Parts for sale
    Last Post: 25th January 2009, 22:02
  4. auto dim rear view mirror
    By smeg in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2007, 07:18
