Results 1 to 10 of 11
Thread: bake lights staying on
    New Member weelad's Avatar
    Belfast
    Default bake lights staying on
    My brake lights have come on constant and no matter what I do they do not go off. I removed the two brake light bulbs but then the bulbs below come on. I had to disconnect the battery last night to prevent my battery being dead this morning.
    also yesterday my boot stopped opening, think it might be the lock mechanism and not related to the brake light problem, but I can't be 100% sure.
    has any one else had this problem, ive tried google but can't find anything completely the same.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    could it be your brake pedel switch is stuck on?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Check Switch On The Brake Pedal Mate..Sounds Suspect
    Snap Tim lol
    Belfast
    thanks very quick, cheers will check now.
    Nov 2010
    BRECHIN
    lol tam,
    is your cruise control working? that uses the brake and clutch switch. would imagine if thats not working it would def be the brake switch.
    Belfast
    located the brake switch ( the one were the brake pedal pushes a button ) and removed the power cable, then brake lights turn off.
    any tips on removing the switch from the bracket, I think by looking at it, it should twist but don't want to try pushing to hard.
    will try cruise control now.
    8 Post(s)
    Quote Originally Posted by weelad View Post
    The brake pedal needs to be pressed before the CC is enabled, so I suspect it won't work.
    Belfast
    yea cruise control not working.
    have ordered a new switch and can't get it until Monday, so phoned someone that specializes in Vauxhall and he said he might have two still in cars, but they can break when removing them. fingers crossed.
    thanks again for all your help.
    Belfast
    The brake light switch is still working. It needs to be pushed back a extra millimeter, don't know if the brake pedal has moved slightly.
    I taped a little bit of a ice lolly stick to the end of the pedal to extend the pedal so it pushes the button on the switch in more.
    is it possible to tighten the brake pedal ?
    Chelmsford
    bake light? Is this the light which shows when the bread is ready?
    Take it out or it will get burnt! Light should go out by itself
  1. Brake Lights Staying On
    By Bethan39 in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 11:59
  2. Brake lights staying on.
    By DTI Dave in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 13:16
  3. rear number plate lights staying on.
    By bigjoe in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2010, 14:11
  4. number plate lights staying on
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 16:18
  5. Auto lights staying on
    By andyemms in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2009, 19:12
