Results 1 to 10 of 17
Thread: Oil filter location 1.9cdti 120
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    Default Oil filter location 1.9cdti 120
    As above, where can I find this? I am planning to do an oil change at the weekend and want to make it as smooth as possible.
    also can someone tell me the capacity of the engine, i.e. how much oil to put in?
    lincolnshire
    if memory serves me correctly its a cartridge filter and its at the front of the engine , black plastic top with a hex nut top , 24mm i think ?? a gallon of oil should be enough , you can put 4 litres in , run it up and then check , top up
    Jul 2009
    Perth, Scotland
    nice one, thanks bembo!... will take a look tomorrow so I'm all prepped
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Fail in that it will be in the same location as the 150, on the back of the engine, facing the N/S wheel.
    Gazza4
    lincolnshire
    mite go have a quick look under my bonnet to make sure !? lol
    lincolnshire
    right ! ignore what i said about the type and location of your filter ! got it mixed up with the DTi engine ! the oil amount will be correct though ! sorry for being a retard
    Jul 2009
    Perth, Scotland
    haha no worries, so it is down the back then? Is it easiest accessible from top or bottom?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by bembo449 View Post
    Tbh the two block don't share much believe it or not, so I'm a bit surprised. Pistons and crankshaft and that's about it I believe.
    They should keep it in the same place saves the confusion. Then the aim of the Human Race is to sidstep simplicity like it's a plague.
    Gazza4
    lincolnshire
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    i know they are different as chalk and cheese gaz , got me wondering where the filter is now ??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    It's at the back, you won't see it, only when you look at the engine from underneath.
    Gazza4
  1. 2.8T oil filter location
    By gibbon7000 in forum Engine & Drivetrain
    Last Post: 15th July 2012, 15:55
  2. Oil filter location?
    By gtr1000 in forum Y & Z30DT Specific
    Last Post: 30th November 2011, 23:34
  3. 2.8 Oil filter Location
    By Largespanners in forum Engine & Drivetrain
    Last Post: 10th October 2009, 16:23
  4. oil filter location
    By Darryl2.2DTI in forum Engine & Drivetrain
    Last Post: 28th October 2007, 19:32
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
vectra c 1.9 cdti oil filter location
vectra c oil filter location
where is the oil filter on a vectra 1.9 cdti
how to change oil filter vauxhall vectra diesel 2007 1.9 cdti
signum cdti 150 oil filter
oil filter location 04 vectra diesel
vectra 1.9 cdti engine oil capacity
vectra c oil filter
oil filter location vectra cdti
vectra c 1.9 cdti oil change
accessing 1.9 cdti oil filter from above
wheres the oil filter located on vauxhall vectra 1.9cdti
2005 Vectra oil filter location
1.9 cdti oil capacity
vectra c 1.9 oil filter location
zafira 1.9 cdti oil capacity
vauxhall zafira diesel oil filter location
oil change vectra 1.9 cdti
vectra c oilfilter location
vaxhall vectra 1.9 cdti oil change
where is the oil fillter on a vauxhall vectra 1.9 diesel
vauxhall vectra 1.9 cdti sri 120 oil filter
how to change oil on vectra c
Vectra c cdti oil type
