Thread: 2.2 member help, its turbo time
    Regular Member daveypower's Avatar
    Mar 2011
    Donegal
    Default 2.2 member help, its turbo time
    lads looking for someone very nice to do a favour for me with abit of turbo knowledge, if they could check something on theres. as ill never find out the info without the help.
    the part is the actuator rod that is connected to the turbo vane lever, just under the turbo vane lever, is a very small threaded bar,
    if someone could measure the length of the very small threaded bar on the side were the vane lever hits it.
    i feel mines has been adjusted and i just want it back where it should be.
    if anyone could help id be very greatfull. i just need to know how much is threaded through on that side.
    Mar 2011
    Donegal
    anyone even a clear photo will do.
    Regular Member Innes's Avatar
    Plymouth
    Do you think its been moved because of the white marking? Thats kind of like a thread lock. See the thread I started awhile back.
    http://www.vectra-c.com/forum/showthread.php?t=126925
    Mar 2011
    Donegal
    thank you so much innes, its not that actual actuator rod but the very small screw behind it, the turbo vane stop point screw,
    but your picture inables me to count the threads on that screw so now i can set it right again, thanks so much, really appreciate it innes,
    top man
  1. Fellow member scammed BIG TIME!
    By lofty in forum General Chat
    Last Post: 20th March 2012, 00:31
  2. service parts .. time to become a full member?
    By chewy71 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2011, 15:09
  3. New member, first time Vectra owner
    By MultiDropper in forum Introduce yourself.
    Last Post: 4th August 2009, 14:36
  4. member stats and latest member...
    By LJ sxi-nav in forum General Chat
    Last Post: 23rd February 2009, 20:48
