Results 1 to 10 of 10
Thread: ok...changed timing belt and.....
    Feb 2009
    Edinburgh
    Default ok...changed timing belt and.....
    it started yay. I didn't kill it.
    However, there is a loud squeel/squeek coming from the engine that gets faster as the engine speed does. How can I figure out of this is coming from the aux belt or something to do with the timing belt? Obviously I had the aux belt pulley and tensioner off. It looks like the aux belt tensioner is vibrating a bit which makes me thing that but I don't want to drive about and it turns out its the timing belt pulley when it fails or something.
    cheers,
    Feb 2009
    Edinburgh
    perhaps I could take the aux belt off and running it for a couple of seconds? car should be able to run off battery for a bit, albeit it won't be charging?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    take fan belt off if still there it cam belt
    answered your own Q lol
    Regular Member macdad's Avatar
    Dec 2007
    East Midlands
    Can't you remove the Aux belt and start her m8 see if noise is still there.To be honest new Timing belts do tend to squeal a bit till bedded in.
    Feb 2009
    Edinburgh
    Quote Originally Posted by macdad View Post
    That makes me feel a bit better. I'll take the aux belt off and see what happens just for my own piece of mind. meant to be driving 180 miles toomorrw, a bit nervous.
    Dec 2007
    East Midlands
    Quote Originally Posted by Big Knox View Post
    Another cause of the dreaded squeal can be to much actual tension on the belt..?is the tensioner ok.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    That would be what id try first.
    Feb 2009
    Edinburgh
    The tensioner is set as per Haynes & the How-2 on here. Pointing to the hole.
    A bit of googling and someone has said it could be coolant on the belt from changing the water pump?
    Feb 2009
    Edinburgh
    aux belt removed, squeel disappeared. Tightened the bolts on the pulley, back on. squeel no more. thanks guys.
    Sep 2010
    in a box
    glad she fixed mate
  1. What Mileage to Get Timing Belt Changed?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2013, 12:48
  2. anyway to do the timing belt without timing tool
    By valvelift in forum Engine & Drivetrain
    Last Post: 15th December 2012, 18:47
  3. How can you tell if a timing belt has been changed?
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:19
  4. timing belt changed with inlet?
    By hairy31 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 13:20
  5. first cam belt changed
    By kdadidog in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 18:51
