Results 1 to 10 of 19
Thread: retrofit oem alarm and deathlock?
    Regular Member Kaies_1981's Avatar
    spain
    Default retrofit oem alarm and deathlock?
    just quetion? Is it possible?
    if posible,how?
    Oct 2007
    Shropshire
    I thought they all had them? It will be possible, anything is, but how much???
    spain
    if can find all part loe cost for the ebay?
    Wales
    Deathlock..cool...I want one..do they come with fire, guns, or both??
    (sorry, I could not resist..I bet you spanish is better than my english though!)
    I think you mean deadlock ywkes..I imagine all vectra-c''s have that
    spain
    sorry for my english!!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yes you can retro fit both.. but will need extencive wiring to your car... if i remember correctly (can miss a part or 2)
    New Body Control Module
    New passenger door loom
    New Passenger door lock
    New Drivers door Loom
    New Drivers door lock
    The same for rear doors.
    New engine loom with the plug for alarm
    New rear end loom with plug for power sounder
    New roofloom
    Alarm sensors interiur car.
    Thats about "it"
    Else you can make up/change your current wiring.. Sulten from norway have retrofittet alarm to his..
    spain
    Quote Originally Posted by kenp View Post
    yes you can retro fit both.. But will need extencive wiring to your car... If i remember correctly (can miss a part or 2)
    new body control module
    new passenger door loom
    new passenger door lock
    new drivers door loom
    new drivers door lock
    the same for rear doors.
    new rear end loom with plug for power sounder
    new roofloom
    alarm sensors interiur car.
    Thats about "it"
    else you can make up/change your current wiring.. Sulten from norway have retrofittet alarm to his..
    ok,thank you,and final must use TECH2?
    Engine : 2.2 Direct
    Correct..
    But the parts you find, must be ready for deadlock and alarm.. else you just aswell just modify your current wiring..
    spain
    I kown.i haver the bcm with code nf,all door lock with the deadlock, the power sunder , so,,,,just make up the loom?
    Engine : 2.2 Direct
    Also the alarm sensor for the cabin and the one for the engine compartment?
    but yes then its all a matter of wiring...
  1. Retrofit ESP ? what do i need....
    By kenp in forum Handling & Braking
    Last Post: 4th June 2012, 17:27
  2. Retrofit TC and ESP
    By Caveman_nige in forum Handling & Braking
    Last Post: 24th January 2012, 00:39
  3. IDS retrofit
    By R2XPT in forum Handling & Braking
    Last Post: 28th September 2011, 20:53
  4. AFL retrofit
    By yoyovento in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:16
  5. Retrofit Aux In
    By leeds vectra in forum Parts for sale
    Last Post: 26th December 2009, 17:29
factory car alarm insignia retrofit
insignia retrofit anti theft system
insignia retrofit alarm
