Results 1 to 10 of 16
Thread: Air Con..
    Oct 2010
    St Neots, CAMBS
    Default Air Con..
    Alas, it is that time of year when everyone goes to use their air con and it doesn't turn arctic as desired.. I have had this same issue, despite running it on the way to work since buying the motor (Nov last year).
    After looking under the bonnet today, it seems that both of the caps on my air con lines are missing! I understand that the larger of the too is the low pressure line. Would these caps missing cause a leak, or does this stink of a previous issue and they have been left off?
    Cheers!
    Engine : 1.9 CDTi
    They are just dust caps
    Regular Member LADmachining's Avatar
    Hampshire
    Usual cause of failure is the condenser behind the front bumper either suffering stone damage, or rotting out and developing a leak.
    My Astra has just done this, was working fine on Sunday, stopped working yesterday. On inspection, found bottom couple of rows of the condenser flapping around in the breeze.... 2 months out of warranty too. Joy.
    Oct 2010
    London
    +1 for screwed condenser, mine was replaced yesterday and I now have lovely cold A/C!
    Sep 2010
    bets please for the AC fault on my 08 SRI/....
    I'm going for condenser
    find out this afternoon
    Oct 2010
    London
    50p on condenser =p
    Mine is a 58 plate
    Sep 2010
    Well,... allgededly no leak! Re-gassed free of charge by VX Priory Park.
    VX state that AC must be re-gassed every year!! pfrrrt,.. must only be Vectras as Toyotas last forever!!
    So.... Just no gas in it!!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Mine was done nearly 2 years ago by kwik fit and still blows icy cold. It is normal for most cars to loose refrigerant over time and need re-gassed.
    If there is a propper leak however I agree it's likely due to a rotten condensor
    Chelmsford
    Quote Originally Posted by chewy71 View Post
    What a load of BS!
    Mine's an 04 plate and never been done, was still icy cold on the way home today!
    Oct 2007
    Shropshire
    Not true, we have a 53 plate vauxhall thats never been done. Regardless of the manufacter if the system stays intact (no leaks due to stone damage or being disturbed) then it will last pretty indefinately as long as its used regulary. (untill last year, new of a p reg car where it had never been done thats 14 years!!!) If it is not used all winter, then mould starts to grow, degrading the seals etc.... Use it at least a couple of times a month all year and it will last....
