Results 1 to 10 of 14
Thread: massive but strange problem
    New Member vectraryan's Avatar
    Oct 2010
    ormskirk
    Exclamation massive but strange problem
    hi all
    my vectra is a 2.2 dti sri on a 2003 plate
    it has suffered a big problem with lighting. when u switch igniton on the main beam come one and stays on untill switching off. when you indercate left or right both front indercators come on but the side repeters do not work.
    when you switch on the main beam lights the side lights do not work and also when reversing they do not work.
    also to throw a spanner in the works the horn does not work
    anyone sufferd this sort of problem before
    please help
    thanks
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    sounds light a earth problem to me mate
    strange , the astra had the same sort of problem that if you put the lights on the horn didnt work , but did when lights were off
    was a big recall for faulty cim units
    yours sounds the same so could also be a faulty cim
    Oct 2010
    ormskirk
    i thought tht but i have also been told that the front and rear fuse boards also go faulty. do u no anyone with a wireing diagram so i can see where all the earths are. also it does not tell you on computer that there are any faults with bulbs do u think the main brain for the computer could be knackerd
    Oct 2010
    ormskirk
    what is the cim mate
    May 2008
    Tyneside
    CIM = column interface module, sits below the steering wheel.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The CIM is one of the many moduals/ECU's modern cars has. Its behind the stearing wheel, but tbh ive never seen a CIM on a vec c do that before but all those systems mentioned do run through it.
    Oct 2010
    ormskirk
    okay would a dignostic check pick up any of this do you think
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Yea, it should do mate, but there are some things you can try yourself for free like the earths as Paul mentioned, some CIM fixes HERE and even something as simple as the fuses. Im not sure but the Body Control Module may even come into it.
    PS, scroll up when you hit the link as for me its taking me to the last post
    Oct 2010
    ormskirk
    hi all i will update u all i replaced the cim and no joy so i got told it would be fuse bored in boot replaced that and still no joy it is turning into a big job now anyone else have any other ideas
  1. Strange problem.
    By Chad! in forum Engine & Drivetrain
    Last Post: 13th October 2011, 14:18
  2. Gear change massive problem
    By stitchi1973 in forum Engine & Drivetrain
    Last Post: 19th December 2009, 12:43
  3. Strange Problem....
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 17th November 2009, 14:08
  4. Massive problem/s. Vectra c 06 plate 3.2 v6 sri
    By vec3.2 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 17:08
  5. strange problem, help please
    By adamjukes01 in forum Engine & Drivetrain
    Last Post: 26th January 2008, 21:55
