Results 1 to 10 of 13
Thread: Replaced egr, engine tickover 1300rpm usually 800.
    Mar 2011
    Default Replaced egr, engine tickover 1300rpm usually 800.
    Vectra 1.9 cdti 120hp
    Hi all I hope you can help. If this has been covered I can't find it and I've been reading the post's for a week.
    A little background, I've had the car a year with no probs, just about to go on m6 last week and car went into limp with spanner lit on dash, got to services, AA looked at it and cleaned out not very dirty egr and away I went no probs apart from engine tickover revs at 1300 where normally about 800, 2 days later same thing again, so after reading up on symptoms on here I changed the egr for new one (thanks to the how2). Engine revs still high at 1200 and spanner comes on intermittent.
    I also put an air induction kit on when I did the egr and took out the air filter box, could that be causing the engine to over rev, or have I missed something.
    Any help appreciated.
    JIm
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds to me possibly:
    - Open Throttle Body circuit (mines done this - sat at 1,500rpm although I had no throttle control). Yours however is a '07/'08 model so it may not be this. Only earlier CDTI's had TB problems.
    - goosed injector(s)
    - sticking turbo vanes
    Gazza4
    Mar 2011
    Thanks for the quick response Gazza.
    Would you expectcodes to be registered, as I have not had any.
    Whats the remedies for the suggested issues, are they suitable for a diyer or is it the dealer only.
    Jim
    Mar 2011
    Update on the above problem.
    Car went into limp again today, so got it home, removed and cleaned boost sensor, tickover still at 1200rpm and still in limp with spanner lit.
    Removed and stripped the throttle body, black crud from egr cleaned it off, opened up the electronic side and there was oil on the main contact, it looks like it had got in via the spindle to the butterfly, (should there be oil here does it need lubrication), put it all back together, limp mode gone, spanner light out but still tickover 1200 rpm.
    I also put the original air filter and box back to see if that was causing the problem.
    Any advice anyone. Thanks
    Jim
    Engine : 1.9 CDTi
    Sounds like you might have an air leak from when you did the EGR valve.
    Mar 2011
    Do you mean an air leak at the gaskets or the valve itself.
    Jim
    Engine : 1.9 CDTi
    Gaskets.
    Either not fitted properly or it has damage to it.
    Not sure if this works on a diesel but try spraying wd40 around the joints and see if the engine note changes (It works on a petrol)
    Mar 2011
    Thanks for that lee gsi, i'll give it a test tomorrow.
    Anybody know if the oil in the throttle body electronics could be causing a problem.
    Jim
    north east
    Totaly unrelated but pop into your local kwick fit for a free battery + Alternator test if you cant find a leak at the egr.
    Mar 2011
    Thanks roswell.
    You say its unrelated, but do either of them give the fast tickover problem. I read on here last week that someone had similar issues I think they changed their battery then the alternator went next day.
    Jim
  1. Replaced chains but engine still noisy
    By enjoy_life27 in forum Engine & Drivetrain
    Last Post: 26th November 2012, 23:41
  2. Replaced Timing Chain - Now Engine Whines !
    By Verns in forum Engine & Drivetrain
    Last Post: 13th June 2012, 22:33
  3. Veccy Sick - engine has been replaced by a Kangaroo !!
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2012, 22:50
  4. Engine noise louder than it was before timing belt was replaced
    By the-converter in forum Engine & Drivetrain
    Last Post: 14th October 2011, 12:26
  5. Alternator replaced but now engine management light on?
    By Dai69 in forum Engine & Drivetrain
    Last Post: 25th July 2010, 10:01
