Results 1 to 10 of 15
Thread: egr needs replacing?
    Regular Member family guy's Avatar
    Jul 2009
    salisbury
    Default egr needs replacing?
    hi all, a few days my emission light came on. nothing unusual it has done it several times in the past but always gone out after a day or two.
    however it is now staying on, for information the EML is NOT on.
    there also seems to be a very slight hessitancey under 2000rpm, not major but also not like it used to be, no really hard shove (remapped, 195bhp).
    now im wondering wot people recommend, giving the engine power restorer a go or just changing the EGR, obviously the power restorer is much cheaper but if the EGR needs doing id rather do it.
    car is a early 2007 SRi CDTi 150 remapped to 195bhp.
    other point ive noticed on here is that some cars might require a tech 2 session after changing the EGR? anyone experienced this
    alos anyone localish (50miles) from salisbury that would
    a- be willing to help me do the de-coke
    b- be willing to change my EGR
    any views guys and gals?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    What remap have you got..?
    Have done a visual check of things, vacuum hoses, swirl bar, EGR electrical connection etc...?
    Aug 2009
    north east
    Try having a look at this how to, http://www.vectra-c.com/forum/showthread.php?t=39441 it's a very basic job and really easy to do. Before you shell out for a new EGR though check everything that Dan has said. I just changed my EGR on saturday and did the 3rd injector upgrade yesterday from following the how 2's on here. Really simple and saves you loads of money.
    Max
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    To all intents and purposes if you have it remapped, why not go back to the remap company and ask if they can disable the EGR valve? Then you can buy a blanking plate for it - no more EGR issues.
    Gazza4
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    That's what I was trying to get at, I should have just come out and said it
    There is no need to ever spend money on a new EGR, with the prices of EGR deletes nowadays.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Sorry Dan.
    Gazza4
    Jul 2009
    salisbury
    There is no need to ever spend money on a new EGR, with the prices of EGR deletes nowadays.[/QUOTE]
    with all due respect, the software from regal is £485 for once it is blanked plus the cost of the blanking plate, plus the labour!
    a new EGR valve is approx. £100!
    i know wot i would rather do!
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by family guy View Post
    Its not just Regal that remove EGR/DPF functions.
    MAS (to name one) do it for £50 - £100 (people have been quoted different prices) - I know what I would do.
    Jul 2009
    salisbury
    i was under the impression that cars with the dpf should not have them removed? How can u tell if a car is so equipped? Does anyone have any info on mas? Or anyone who has had there egr blanked recommend a company? More importantly will my EMl go out if the egr was blanked?
    Engine : 1.9 CDTi
    You can clean them out and sometimes that helps.
    If you can make it over to Portsmouth I can give you hand removing it and giving it a clean.
  1. Replacing cim ?
    By Mr Owens in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 10:10
  2. replacing the REC
    By les287 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 04:14
  3. Replacing Tie Rod and Tie rod end
    By chazuwe in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2011, 13:46
  4. Replacing the CIM
    By Martyn21 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:22
  5. Replacing DMF
    By RikD in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 21:55
