Right then here it goes
Been having a problem the past week or so with my cd70 it would randomly turn itself off whilst listening to the radio or with the sat nav running and then back on again ( flat road no bumps or potholes etc and all the wiring is secure in the plug ) last night i noticed the navi has stopped working as the screen was blank so i tried to eject the disc and nothing i then pressed the navi button on the front control panel and still nothing yet everything else still works so i ended up having to strip it to remove the disc tonight, whilst it was in bits i swapped the ribbon cables around so the navi disc unit was being powered by the music side in order to rule out the disc drive being faulty and it works fine so i know thats not faulty. Since the navi has died the unit no longer turns itself on and off like it did.
So basically i`m left with a cd70 that works but the navi side of it is completely dead ???
Is this a known fault or has it happened to you ?
Does anyone know what could be the problem and more importantly where i can get it fixed ?
I`m well outside of the warranty as its fitted in an 06 plate and i dont want to be buying a new unit just for the navigation i would rather put the extra to it and get the VXMMI unit if i had to go down that road and with needing a new manifold that is higher on my list or priorities but i still need it working as it should
Andre
