Results 1 to 10 of 17
Thread: rear discs
    Aug 2010
    wilts
    Default rear discs
    can someone help me with how to get the rear brake discs off on my signum 2.0 T as i need to replace them not sure how they come offsome help or a how to would be helpfull thanks
    Regular Member andy-j's Avatar
    Apr 2008
    stoke on trent
    wheel off, brake caliper off, one little grub screw disc off. simples.
    Carrier off too - and that's the biggest ***** part of the job...
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Devon
    Quote Originally Posted by Penfold101 View Post
    I have 292mm rears. When I changed mine I did not need to take the carrier off - the discs came on off with them in place!
    Quote Originally Posted by dae36 View Post
    I managed to change my old solid rears by only removing on of the bolts and bashing the carrier round out of the way - the other bolt was seized in...
    Never tried it with the 292's though...
    Aug 2010
    wilts
    Thanks for all the help i did have feeloing that it was just grub screw that held it on but was not sure thanks again
    Jan 2010
    York
    I've just wasted an evening of blazing sunshine trying to do this.
    2 hours tops...or so I thought!
    Nice new set of Mintex discs and pads, spent an hour trying to get the f*****g thing back together on one side - no ****** has said that you need a special tool to wind the piston back in due to the handbrake design!
    One of the pads had completely knackered itself (probably cheap **** ones that were fitted just before I bought the car 12000 miles ago), the handbrake has adjusted itself so much that there is no way the thing will go back together without this tool - which, luckily, a mate has so I can crack on tomorrow night.
    Sodding cars!!!!!
    Aug 2010
    wilts
    now im abit worried
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    read the threads some have been lucky and got away with long nosed pliers but recommend the wind back tool
  1. rear discs
    By tomo610 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2011, 08:16
  2. rear discs
    By marc vectra sri in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2011, 20:27
  3. rear discs
    By niicckk in forum Handling & Braking
    Last Post: 6th September 2010, 23:14
  4. Rear discs
    By stuk2000 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2009, 18:25
