Results 1 to 10 of 17
Thread: Whould wheels higher car??
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default Whould wheels higher car??
    My vec is lowered on 35mm springs and when i did it it on sri wheels with 225/45/17 tyres on. I have since put on xp2 wheels with 225/45/18 tyres on so my new wheels have a same side wall profile as my old wheels but ofcourse my new wheels are 1
    Inch bigger... My question is would this actually make the car stand higher?? As since ive put my 18's on i havent wacked my
    Splitter on anyting! Or is it just me?? I was thinking about 19's next but dont want to higher car anymore! Thanks for any responses
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    Yer makes it higher mate by an inch id say
    scotland
    Quote Originally Posted by bangty 1 View Post
    no its only half inch , half at bottom and half at top of wheel
    Sep 2010
    in a box
    Quote Originally Posted by gsxrster View Post
    Sep 2010
    Leeds
    So if i put 19's on it would be higher again?? Even if i used 35 wall profile tyre?? So i mite aswell av not bothered lowering car then?? Or if i hadnt wud it be even higher!!!!!
    Barnsley
    u sure 225 45 17 ??? if so the 225 45 18 should affect speedo so be carefull if urcar is set up to 225 45 17 then idealy you need 225 35 18 to make it stand same as it did with 17s and will correct ur speedo
    Sep 2010
    in a box
    Quote Originally Posted by Jow20 View Post
    yes mate my 20s made mine in to a 4x4 lol but yer if you left it as norm it would be higer
    Sep 2010
    Leeds
    215/50/17 was correct for the old sri wheels, but when i replaced them i chose 225/45/17 as they was cheaper, wider and lower profile so looked better. It is an option in the handbook i believe for 17's
    As above, there would be a slight increase, but the profile size of the tyre should decrease
    Once you go above 18" you need to further shorten the springs and dampers, as the sports suspension is designed for the 18" wheel, so that the 16" (standard) and 18" (sports) are at the same height, thus making the 17" appear lowered
    Sep 2010
    Leeds
    So has the xp wi snoflakes got a different suspension to normal sri's??
  1. Higher grade petrol
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2011, 11:10
  2. whould you buy a......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2009, 22:19
  3. higher or lower ?
    By signumboy in forum Styling
    Last Post: 28th February 2008, 12:04
  4. oh no its higher on one side
    By topline in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2006, 22:25
  5. Higher at the front!
    By Doug-SRidirect in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2006, 14:10
