Thread: Air Conn not working
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Air Conn not working
    Switches ok, they light up and fan cuts in, but no cold air?, anything I can do as a process of elimination, or just go for a re-gas? how much is a re-gas?
    Is the condenser near the front of the rad?
    Barnsley
    mine same 08 low milage 2
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'd go for a re-gas. £30 at KwikFit
    Oct 2007
    south wales
    If a leak in system/condenser would it show after a re-gas?
    Engine : 1.9 CDTi
    They should do a vacuum test where they should hold it at vacuum for 30 minutes to check for any leaks.
    If they are quicker than 45 minutes doing your car I doubt they have done a proper job.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by PeterVV View Post
    KwikFit should be able to detect a leak when the re-gas it, as they do a "leak test"
    east sussex
    Default Got air con pump if needed
    Hi i have an aircon pump if you need one also its located at the front very visible to the left of the exhaust manifold.Re gas usually contains an additional leak detection fluid aswell try that first u can also buy air con regassing diy kits on ebay from memory £30 delivered.
    11 Post(s)
    Quote Originally Posted by nismo128 View Post
    Don't bother.
    They're not called DIY death kits for nothing.
    A DIY can won't tell you that you have a leak either until you've used up all its contents and still have a non operating AC system.
    Oct 2010
    London
    Mine is in at the moment having the condenser replaced, has a nice hole in it!
    Probably the same on yours! But definately get it checked properly and do not use the DIY kits for the reasons above!
  1. radio working, not working, working again
    By J P S in forum Electrical & ICE (including SatNav)
    Last Post: 22nd February 2012, 00:59
  2. Replies: 4
    Last Post: 11th November 2011, 12:05
  3. Replies: 0
    Last Post: 10th November 2011, 22:58
  4. Working out MPG
    By justin32 in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2011, 10:51
